6 Replies Latest reply on Nov 16, 2009 4:41 AM by diditin
    arraycollection into XMLlistcollection
    diditin Level 1
      Hi all,
      I am trying to create my xmllistcollection since days, and getting soo unsuccessful each time...
      I have a flat simple arraycollection like :
      id_orderclient_nameorders_name
      1client_name 1order_name 1
      2client_name 2order_name 2
      3client_name 3order_name 3
      4client_name 1order_name 4
      Objective: I want to display the above data in a tree, group by client_name.
      Please can you help me to create that xmllistcollection ?
      ps: what i have done so far:
      [Bindable]
      private var myXMLlist:XML = <clients></clients>;
      [Bindable]
      private var XMListcol:XMLListCollection;
      private function createXML():void
           XMListcol = new XMLListCollection;
           var clientNamePrev:String;
           for (var i:int = 0; i < allOrders_array.length; i++)
                var ordName:String = allOrders_array.getItemAt(i).orders_name;
                var idOrders:String = allOrders_array.getItemAt(i).id_orders;
                var clientName:String = allOrders_array.getItemAt(i).client_name;
                var clientNameTag:XML = <clientname>{clientName}</clientname>;
                //Alert.show("idOrders:"+ idOrders+ "order name:"+ ordName);
                var new0rderTag:XML = <ordername id={idOrders}>{ordName}</ordername>;
                if(clientNamePrev == clientName)
                     Alert.show("clientNameTag: "+ clientNameTag);
                     clientNameTag.appendChild(new0rderTag);
                else
                     //Alert.show("ord Prev: "+clientNamePrev + " orderName: "+ clientName);
                     myXMLlist = myXMLlist.appendChild(clientNameTag);
                clientNamePrev= clientName;
           XMListcol = new XMLListCollection(myXMLlist.children());
           Alert.show("listxml: "+ myXMLlist.descendants());
        • 1. Re: arraycollection into XMLlistcollection
          Flex harUI Adobe Employee
          What would you want the XML representation to look like?
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: arraycollection into XMLlistcollection
            diditin Level 1
            Hi Mr. Alex,
            Thank you for replying me. My XML should probably look like the below format:
            <clients>
                <clientname name = 1>
                      <ordername>X </ordername>
                      <ordername>Y </ordername>
                </clientname>
                <clientname name = 2 >
                      <ordername> Z </ordername>
                </clientname>
                <clientname name = 3>
                      <ordername>A </ordername>
                </clientname>
            </clients>
            So that i have a tree like:
            -1
            -->X
            -->Y
            -2
            -->Z
            -3
            -->A
            All orders having the same client name should be regrouped.
            thank you
            • 3. Re: arraycollection into XMLlistcollection
              I think you want to sort the AC by clientName first.  You seem to be on the right track otherwise.
              Alex Harui
              Flex SDK Developer
              Adobe Systems Inc.
              • 4. Re: arraycollection into XMLlistcollection
                diditin Level 1
                Hi
                Do you know how could i access the attribute 'id' from the tag '<ordername id =xx>'?
                please find below the solution to my difficulties:
                     var clientNamePrev:String = "";
                     var clientNameTag:XML;
                     //Alert.show("arraylength : " +allOrders_array.getItemAt(20).client_name );
                          var new0rderTag:XML = <ordername id={idOrders} label={ordName}/>;
                          if (clientNamePrev == "")
                               clientNameTag = <clientname label={clientName}></clientname>;
                          else if(clientNamePrev == clientName)
                               //Alert.show("clientNameTag: "+ clientNameTag);
                          else if(clientNamePrev != clientName)
                          else
                               Alert.show("Please contact Administrator @ yy@xx.com", "Alert");
                          if (i == (allOrders_array.length - 1))
                     //Alert.show("listxml:" + XMListcol);
                Thank you
                • 5. Re: arraycollection into XMLlistcollection
                  Attributes are accessed via "@" as in someTag.@id
                  Alex Harui
                  Flex SDK Developer
                  Adobe Systems Inc.
                  • 6. Re: arraycollection into XMLlistcollection
                    diditin Level 1
                    Yeah, it's quite different from the way we usually do while accessing arraycollection. XMLListCollection proceeds as follows:
                    Eg of my XML:
                    <clients>
                         <clientname label=CLIENTNAME>
                              <ordername id=12332 label=MYORDERNAME1/>
                              <ordername id=53423 label=MYORDERNAME2/>
                                etc..
                         </clientname>
                         etC..
                    </clients>
                     private function disactiveOrder(evt:CloseEvent):void
                                   //GET XML NODE FIRST. "list_orders" is the name of my TREE
                              var node:XML = list_orders.selectedItem as XML;
                                   //IF USERS ACCEPTS CONFIRMATION
                              if (evt.detail == Alert.OK)
                              //call function
                              AMF_orders.disactiveOrder.send(Number(node.@id));
