2 Replies Latest reply on Nov 15, 2009 2:08 PM by try67
    Form Field Common Properties
    Jim MacD Level 1
      How can Form Field Common Properties be changed? After a form reset, I want to change a Form Field Common Properties to 'Visible but doesn't print'.
        • 1. Re: Form Field Common Properties
          You can either change each field individually if each field is uniquely named or use the top hierarchal name for fields named using the hierarchical naming structure.
          If it is every field that needs to be changed, you can obtain the entire list of filed names through Acrobat's JavaScirpt 'getNthFieldName' method and the number of fields using the 'numFields' propery of the doc object.
          Enumerate through all of the fields in the document.
          for (var i = 0; i < this.numFields; i++)
          console.println("Field[" + i + "] = " + this.getNthFieldName(i));
          Yoproperlyu can modify the above script to set the field's 'display' property rather than print the field name to the console.
          • 2. Re: Form Field Common Properties
            You need to set the field's display property to display.noPrint
