4 Replies Latest reply on Jul 22, 2008 1:21 AM by ryanc44
    Menu Tracer Problem
    ryanc44
      I have a horizontal text menu that has a small graphic under it that slides horizontally to the menu item you rollover. The code is straightforward:
      stop();
      Button_AboutUs.onRollOver = function() {
      Nav_Slider.xMove = Button_AboutUs._x;
      Button_OurWork.onRollOver = function() {
      Nav_Slider.xMove = Button_OurWork._x;
      Button_ClientList.onRollOver = function() {
      Nav_Slider.xMove = Button_ClientList._x;
      Button_Contact.onRollOver = function() {
      Nav_Slider.xMove = Button_Contact._x;
      The sliding graphic "Nav_Slider" has this code attached to it directly:
      onClipEvent (load) {
      xMove = _x;
      easeSpeed = 5;
      onClipEvent (enterFrame) {
      _x += (xMove-_x)/easeSpeed;
      That all works fine, but what I noticed is that the tracer graphic will just stay under the last menu item I roll over once I move the mouse away from the navigation, so I wanted to have the tracer graphic return to its default position if a navigation menu item was not rolled over within say a 2 second time period. So I thought I could add code like this:
      Button_AboutUs.onRollOut = setTimeout(Nav_Slider_Reset, 2000, "2 second delay");
      Button_OurWork.onRollOut = setTimeout(Nav_Slider_Reset, 2000, "2 second delay");
      Button_ClientList.onRollOut = setTimeout(Nav_Slider_Reset, 2000, "2 second delay");
      Button_Contact.onRollOut = setTimeout(Nav_Slider_Reset, 2000, "2 second delay");
      function Nav_Slider_Reset() {
      Nav_Slider.xMove = 0;
      But that doesn't appear to work. Any help would be appreciated.
        • 1. Re: Menu Tracer Problem
          Level 7
          I think it's just that you have the form wrong:
          >>delay");
          Should be:
          Button_AboutUs.onRollOut = function(){
          setTimeout(Nav_Slider_Reset, 2000);
          Dave -
          www.offroadfire.com
          Head Developer
          http://www.blurredistinction.com
          Adobe Community Expert
          http://www.adobe.com/communities/experts/
          • 2. Re: Menu Tracer Problem
            Level 7
            Actually you should probably include the onReleaseOutside in there:
            Button_AboutUs.onRollOut = Button_AboutUs.onReleaseOutside = function(){
            Dave -
            www.offroadfire.com
            Head Developer
            • 3. Menu Tracer Problem
              ryanc44 Level 1
              Hi Dave- that solved the problem, but opened up a new one. I notice now that when I preview my movie and rollover the first nav button the tracer stays in place, but once I rollout and rollover another nav button the tracer does follow to the other button, but within the 2 second interval of rollingout of the first button it will return to it's default position even though I'm still rolledover on another button. I think it's constantly trying to run my Nav_Slider_Reset function because I've rolledout of the first button regardless of it being rolledover on another button. My guess is I need to somehow incorporate the clearTimeout Function now- this is what I tried but it doesn't work:
              stop();
              clearTimeout(ns_timedProcess);
              Button_AboutUs.onRollOut = Button_AboutUs.onReleaseOutside=function () {
              var ns_timedProcess:Number = setTimeout(Nav_Slider_Reset, 4000);
              Button_OurWork.onRollOut = Button_OurWork.onReleaseOutside=function () {
              Button_ClientList.onRollOut = Button_ClientList.onReleaseOutside=function () {
              Button_Contact.onRollOut = Button_Contact.onReleaseOutside=function () {
              • 4. Re: Menu Tracer Problem
                ryanc44 Level 1
                Anyone else have an idea?
