1 Reply Latest reply on Nov 15, 2009 11:34 AM by Adam Cameron.
    Problem with white space
    ACS LLC Level 1
      I am trying to remove all the white space created in the HTML by CF processes. I did have this working ok with
      <cfsetting enablecfoutputonly="true">
      But now I'm noticing it's not longer working, I know I saw it working!
      I'm outputting a string to the HTML, such as ABCDEFG, I don't want any white space from the queries above it, and yet I'm getting a significant amount of white space/line breaks.
      I also tried <cfsetting enablecfoutputonly="true"> but this did not do the trick
      The only way is to set the CFadmin to supress white space, but that's fine on local dev, however I use a shared server where I can't control the CFadmin settings and it's not switched on
      Appreciate any help
      Mark
        • 1. Re: Problem with white space
          Adam Cameron. Level 5
          Other things you can use are <cfsilent>, <cfprocessingdirective> and making sure all your functions are specifically set to output="false".
          Custom tags are particularly bad at generating output, so it's vital to put <cfsilent> around as much of the tag code as possible.
          What do your hosting providers have against switching whitespace management as a matter of course, anyhow?
          Adam
