2 Replies Latest reply on Nov 17, 2009 6:02 PM by andre215
    RSL problem in Flex3..
    andre215
      I am new to Flex and need help to use Runtime Shared Library in my project.
      I am trying to create simple RSL Project, but it always gives me error when I try to run from my Tomcat Application Server :
      VerifyError: Error #1014: Class mx.core::Application could not be found.
           at flash.display::MovieClip/nextFrame()
           at mx.managers::SystemManager/deferredNextFrame()
      I am using simple ant-compc and ant-mxmlc to compile my library project and main project :
         <target name="build" depends="clean" >
              <compc output="${FLEX_CUSTOM}/bin/CustomLibrary.swc">
                <include-sources dir="${FLEX_SRC}" includes="*"/>
              </compc>
         </target>
        and..
        <target name="compile">
           <mxmlc file="${FLEX_SRC}/RSLExample.mxml"  output="${FLEX_DEPLOY_DIR}/RSLExample.swf">
                <load-config filename="${FLEX_HOME}/frameworks/flex-config.xml"/>
                <compiler.external-library-path dir="${FLEX_CUSTOM}/bin" append="true">
                      <include name="CustomLibrary.swc" />
                </compiler.external-library-path>
                <runtime-shared-libraries url="CustomLibrary.swf" />
           </mxmlc>
        </target>
      When I called from my Tomcat using 'localhost:8080/app', I always get this error. I also have copied 'framework_3.2.0.3958.swz' to  my deployment folder, but this problem is still there.
      Any ideas as to what I am doing wrong? I really need help about this..
      I really appreciate any help and suggestion ..
      Thx in advance,
      Andre
