8 Replies Latest reply on Nov 25, 2009 6:52 AM by Jochem van Dieten
    FlashBuilder beta 2 hangs on licensing
    Jochem van Dieten Level 4
      When I start FlashBuilder beta 2 on WinXP Sp3 I see the following symptoms:
      - UI displays;
      - about 2 seconds later the license key dialogue displays asking for a key or a trial;
      - immediately afterwards the CF builder start page shows in the main FB window and the main FB window receives focus.
      - the CPU usage returns to 0;
      - when I click anywhere in the main window it won't work;
      - when I switch focus to the license key dialogue the CPU jumps to 100% and the UI becomes unresponsive and after 5 minutes the application exists.
      I have tried:
      - start FB with the -clean switch;
      - to rerun the mini setup for the shared libraries (setup.exe from the install.support\builder-common-mul-win folder);
      - run the license recovery tool (licenserecover.exe from install.support\LicenseRecovery);
      - restart the FlexNet service;
      - restart the OS;
      - remove and install FB.
      I have attached the following documents in a .zip file:
      - alm.log
      - amt.log
      - stacktrace.txt
      - swtag.log
      stacktrace.txt is a jstack trace of the FB application while it is in an unresponsive state eating the CPU. It shows FB working on com.adobe.flexide.amt.AMTLib.AMTObtainProductLicense(Native Method) and is stable (i.e. when I do multiple stack traces the results are always the same).
      Other applications, both FC beta and registered versions of Acrobat Pro, Flash Pro etc. function correctly.
