0 Replies Latest reply on Nov 16, 2009 6:20 AM by setzergabbiani
    Remote service compiler error
    setzergabbiani Level 1
      Hello,
      I'm facing a weird problem when trying to compile a Flex project with the -services <path-to-configuration-xml> argument. When I remove the argument, everything compiles, but when I add this argument, I get the following errors:
      DescriptionResourcePathLocationType
      1084: Syntax error: expecting rightbrace before end of program.MyProject
      Line 206Flex problem
      1084: Syntax error: expecting rightbrace before end of program.MyProjectLine 206Flex problem
      1084: Syntax error: expecting xmltagendend before end of program.MyProjectLine 206Flex Problem
      1100: Syntax error: XML does not have matching begin and end tags.MyProjectLine 206Flex Problem
      1104: invalid xml nameMyProjectLine 183Flex Problem
      I've checked my services-config.xml, but everything is ok. (See attached file)
      What could be causing it?
