0 Replies Latest reply on Nov 16, 2009 7:20 AM by jmurphy67
    [svn:fx-trunk] 11837: Localization property file update 4.0.0.11824M
    jmurphy67 Level 1
      Revision: 11837
      Revision: 11837
      Author:   jimurphy@adobe.com
      Date:     2009-11-16 07:19:54 -0800 (Mon, 16 Nov 2009)
      Log Message:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ja_JP/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ru_RU/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/core.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_da.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_de.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_es.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_fi.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_fr.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_it.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_ja.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_ko.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_nb.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_nl.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_pt.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_ru.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_sv.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_zh_CN.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_zh_TW.properties
