2 Replies Latest reply on Nov 16, 2009 12:16 PM by gtbus
    Does removePopUp method remove the object from the display list?
    gtbus Level 1
      I am creating an AIR application that uses several pop-ups, and I want to recuperate as much memory as possible from closed popups with each Garbage Collection.  Reading through forums / blogs / documentation I see object instances created by pop-ups stay in memory (not GC'd) until:
      - all references to the object are = null (nulled)
      - all event listeners on the object are removed (or are weakly referenced)
      - the object is removed from the display list.
      My question is:
      Does
      PopUpManager.removePopUp(this);
      I am using PopUpManager.createPopUp() to instantiate an mx:TitleWindow display object container.
      The remove function closes the pop-up, however, I am unsure if it is "removed from the display list" completely.
      A straightforward answer is best, anything that moves me in the direction to answer the question is great. (Also helpful: how can I view the objects in the display list at a certain point during the application's execution?)
      Thanks to all!
      gtb
