0 Replies Latest reply on Nov 16, 2009 10:19 AM by Carol L. Frampton
    [svn:fx-trunk] 11851: Halo label using FTETextField was incorrectly truncating because the textWidth incorrectly included the 2 pixels of PADDING_LEFT .
    Carol L. Frampton Level 2
      Revision: 11851
      Revision: 11851
      Author:   cframpto@adobe.com
      Date:     2009-11-16 10:19:38 -0800 (Mon, 16 Nov 2009)
      Log Message:
      Halo label using FTETextField was incorrectly truncating because the textWidth incorrectly included the 2 pixels of PADDING_LEFT.  Correct textWidth which should be the max textLine.textWidth.  Also need to maintain the width to use to clip the text which is max x + textWidth since the text could be indented and/or aligned and all has left padding of 2 pixels.
      QE notes: 80 FTETextField failures.  bitmaps need updating.  Peter knows this is coming
      Doc notes:
      Bugs: SDK-24176
      Reviewer: Gordon
      Tests run: checkintests, FTETextField
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24176
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/mx/core/FTETextField.as
