2 Replies Latest reply on Nov 17, 2009 12:06 PM by Linda Nicholls
    CS4 Slice Chaos...someone splain me what I'm doing wrong?
    zeroskillz Level 3
      Alrighty, so I'm spitting out a design comp as html and images--basicly a demo for a site which includes some rollover/selected button behavior. Thses buttons were created using the 'convert to symbol' command, and the different states made, etc.
      Once I export to html, things go horribly awry, but only sometimes. So I figure it's got to be me...
      here's a URL rto show what I mean:
      http://69.44.221.56/demo/tedscrap/FWproblem/Community.htm
      Only the 'Community' and 'Amenity' buttons do anything.
      Why does the output happen correctly for amenities and not community?
      FW png attachedto this message.
      Any insight is greatly appreciated.
      Thanks!
      -Ted
      Pic for quickeference: FW on left screen, Firefox Preview on right...
        • 1. Re: CS4 Slice Chaos...someone splain me what I'm doing wrong?
          zeroskillz Level 3
          I got the answer from another forum, so I thought I'd post here in case someone needs the answer in the future:
          From www.fireworksguruforum.com
          "I think I found the problem: in the export dialog there is an Options... button. Open this and go to the Table tab - your file had "Single table" selected, which was forcing FW to try and recreate the layout with a single table, but your page layout is complex enough that you need to use Nested Tables or to allow FW to select the best table structure using 1-pixel transparent spacers. When I switched the Table "space with" option to nested or 1-pixel transparent spacer, the exported page looked correct."
          Thanks again to the fireworksguruforum fo helping me out withthat.
          -Ted
          • 2. Re: CS4 Slice Chaos...someone splain me what I'm doing wrong?
            Linda Nicholls Level 4
            You don't need to use nested tables or spacers if you slice correctly. Next time, try this:
            Click on the rulers to pull guides over the image to mark off where you want to draw the slices. Keep in mind that the slices you draw will be creating a table, and that your table shouldn't have any overlapping rows or columns. Rows and columns should line up neatly above and below each other, and side by side, like a checkerboard. That doesn't mean that the rows and columns all have to be the same size. Just don't stagger slices, like bricks in a wall. If you do, your table will break and the image will look like it exploded.
