This content has been marked as final.
Show 1 reply
1. Re: AVI / M4V Editing & Exporting Problems
JSS1138 Nov 16, 2009 1:03 PM (in response to jens0771)There seems to be a new reason for this error.
AME doesn't actually export the Premiere sequence. It first makes a copy, and uses that to perform the actual export. This allows you to keep working on the original while export happens in the background. But here's the problem, Premiere can apparently corrupt the project file when it makes a copy for AME to use. The file is right where AME thinks it should be, but because it's corrupt, it "can't read" the file, and you get the error.
I haven't found a solution yet.
