0 Replies Latest reply on Nov 16, 2009 1:41 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 11865: Fix bugs and regressions around List selection and drag and drop
    Evtim Georgiev (Adobe) Level 2
      Revision: 11865
      Revision: 11865
      Author:   egeorgie@adobe.com
      Date:     2009-11-16 13:41:43 -0800 (Mon, 16 Nov 2009)
      Log Message:
      Problems:
      1. DND caused regression in ctrl+click deselection because it prevented listeners for mouse up to be attached unless dragEnabled was true (SDK-24210).
      2. ListBase check for commitSelection() relies on internal variables that are updated before calling itemSelected(). If the item selection at that point causes layout manager to validate properties before returning, the List will enter into a second commitSelection() while the first is mid-way through below on the stack. Net result is the selection is undone giving the illusion the item is not selected (SDK-24132, SDK-24105, SDK-24130).
      Fixes:
      1. Add listeners for mouse up when either DND is enabled, or there's pending selection on mouse up.
      2. ListBase, commitSelection: commit internal variables state before calling itemSelected to prevent entering a second time into commitSelection.
      QE notes: None
      Doc notes: None
      Bugs: SDK-24132, SDK-24105, SDK-24130, SDK-24210
      Reviewer: Deepa
      Tests run: checkintests, mustella (gumbo/components)
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24210
          http://bugs.adobe.com/jira/browse/SDK-24132
          http://bugs.adobe.com/jira/browse/SDK-24105
          http://bugs.adobe.com/jira/browse/SDK-24130
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/List.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ListBase.as
