0 Replies Latest reply on Nov 16, 2009 4:18 PM by kevinklin
    [svn:fx-trunk] 11873: Fix for http://bugs.adobe.com/jira/browse/SDK-22800.
    kevinklin Adobe Employee
      Revision: 11873
      Revision: 11873
      Author:   klin@adobe.com
      Date:     2009-11-16 16:17:50 -0800 (Mon, 16 Nov 2009)
      Log Message:
      ButtonBase.as - Subclasses of ButtonBase were updating properties like selected and selection in the clickHandler. This caused the buttons to be in an intermediary state between the mouse up event and the mouse click event. I've added a new protected method called buttonReleased() that is called during the mouse up handler when the mouse is captured and when the mouse is hovering over the button. This allows the button to smoothly transition between states like down and overAndSelected without passing through the over state. I also separated out some of the systemManager mouse up handlers into a separate handler.
      ToggleButtonBase.as, RadioButton.as - Moved the update code from clickHandler to buttonReleased.
      QE notes: No
      Doc notes: No
      Bugs: SDK-22800
      Reviewer: Evtim
      Tests run: checkintests, Button, ToggleButton, RadioButton
      Is noteworthy for integration: Yes
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RadioButton.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ButtonBase.a s
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ToggleButton Base.as
