0 Replies Latest reply on Nov 17, 2009 12:18 AM by Peter Farland
    [svn:fx-trunk] 11885: Integrating Sujata and Min' s changes from the latest approved FXGUtils from CT changelist 633842.
    Peter Farland Level 3
      Revision: 11885
      Revision: 11885
      Author:   pfarland@adobe.com
      Date:     2009-11-16 20:19:46 -0800 (Mon, 16 Nov 2009)
      Log Message:
      Integrating Sujata and Min's changes from the latest approved FXGUtils from CT changelist 633842.
      CT Bugs Fixed:
      - bug #2480280 (FXGUtils: pixelHinting setting to true for SolidColorStroke doesn't work.)
      - bug #2479187(FXGUtils is drawing compiled FXG items is off by half a pixel)
      - Fixed other instances of rounding errors from casting to int.
      - Bug 2480289: Compiling richtext content markup in MXML with FlexSDK runtime option is throwing errors.
      -  LinkFormats cannot be child of  tag has children, you do not get a compile error.
      -  Bug  2477649: FXGUtils needs to support setting justificationStyle to prioritizeLeastAdjustment for RichText.
      -  Bug 2477661: Incomplete error message when an invalid textAlign attribute value is provided.
      -  Bug 2444256: FXG compiler fails on percentage lineheight inside formatted text content.
      QE notes: Please investigate 2 mustella failures for FXG stroke tests.
      Doc notes: N/A
      Bugs: N/A
      Reviewer: Sujata, Min
      Tests run: checkintests, mustella fxg
      Is noteworthy for integration: Yes
      Modified Paths:
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGConstants.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_en.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/swf/FXG2SWFTranscoder.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/ContentPropertyNode.j ava
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/EllipseNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/RectNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/RichTextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/AbstractRich BlockTextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/TextHelper.j ava
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/TextProperty Node.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/LeadingModel.ja va
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/ImageHelper.java
