7 Replies Latest reply on Sep 21, 2012 8:47 PM by Cheril2
    Artwork on a Transparent Art Board
      I’m trying to do something very simple yet can’t seem to figure it out.
      I’d like to work with my vector graphic line drawing on a completely transparent background. My goal is to add color in blocks behind the line drawing.
      I know how to import my artwork, placing it on the art board, and then make a Live Trace. And I understand how converting it into Live Paint will create outlines. But it looks like if I want to remove the default color of the art board (White), I need to also remove the color of the line. And I don’t want to have to re-color all of my line.
      I remember in the old days of Streamline how this was possible. (My last version of Illustrator was the original CS, so I’m way behind.) It looks like the only option for coloring artwork in CS4 is to do it exactly inside the lines, super-clean. And I’d like the freedom to paint behind the line.
      Does anyone have a work-flow that they could share with me to achieve a line drawing on a transparent background with a second layer underneath for color?
      Thank you.
        • 1. Re: Artwork on a Transparent Art Board
          [scott] Level 6
          I don't fully understand your dilemma. All Illustrator files have a transparent background by default.
          It sounds like your issue may be with Live Trace. Try choosing "Tracing Options" from the small downward arrow in the control Panel next to the Live Trace button. When the options come up, tick the "Ignore White" box and try the tracing options you like. That should eliminate areas with white fills.
          • 2. Re: Artwork on a Transparent Art Board
            PrepressPro1 Adobe Community Professional
            You can go View>Show Transparency Grid in Illustrator. This will give you some reference to what is White and what shows through to Transparency. Hope this helps. I never use this view option because I have become accustom to knowing the artboard white is actually transparent. Or if there is a doubt in my mind I just make a big square of color and send it the the back of the bottom layer to see if my artwork has the correct show through/compound paths.
            • 3. Re: Artwork on a Transparent Art Board
              A.G.Fish Level 1
              This helps me a lot. The white doesn't appear and I don't have to deal with deleting the color showing. I've set this as my default.
              • 4. Re: Artwork on a Transparent Art Board
                A.G.Fish Level 1
                Brilliant as well!
                "Showing the grid" lets me see what is transparent and what isn't.
                I wish I could have given you a "Correct Answer" as well but the forum only allows for one.
                Thank you for your help!!
                • 5. Re: Artwork on a Transparent Art Board
                  Cheril2 Level 1
                  Your Illustrator Artboard might be transparent by default, but mine certainly isn't. I have been turning myself inside out trying to work out how to export a PNG file to PowerPoint 2010. I thought that PNGs should be transparent by nature! You can't use the Web export either as the quality is too poor. No, I haven't optimized it!
                  • 6. Re: Artwork on a Transparent Art Board
                    Cheril2 Level 1
                    Win 7, Illustrator CS5, plenty of RAM & ROM
                    I am having trouble with PNG transparent files also. This work is from an original EPS, so no tracing is involved. I wish to use the file in PowerPoint so I need the transparency. As I mentioned above, I thought that PNG files were natively transparent, unless you add a coloured background.
                    I have tried flattening the file but this does not work.
                    Only saving as a web file maintains the transparency, but this quality is too poor to use.
                    • 7. Re: Artwork on a Transparent Art Board
                      Cheril2 Level 1
                      I have worked it out at last. You cannot use the export for Microsoft Office as this carries a white background with it! The only option is to use the 'Export' option and this carries a top quality transparent file. It really shouldn't have been this difficult.
