1 Reply Latest reply on Nov 17, 2009 3:26 PM by Flex harUI
    Try catch question
    flexchief
      I've got a a problem with one of my methods called addToTop50(). Basically it's giving me a an error saying "TypeError: Error #1010: A term is undefined and has no properties" because one of the values i'm trying to add to a db table are not all present.
      I need to know if by adding the try catch blocks as shown in the attached code, should this solve my problem and allow the code to run without throwing an error and pausing the application as the debuger does?
      private function addToTop50():void
             // Add the track to Top50 & AllPlayedTracks db tables
           if(thumbnailTileListItemClicked == true)
                listTileListItemClicked = false;
                coverflowClicked = false;
                albumTrackClicked = false;
                searchFlowItemClicked = false;
                recommendedFlowItemClicked = false;
                try
                     if(currentGenre[thumbnailTilelist.selectedIndex].trackPath != null && currentGenre[thumbnailTilelist.selectedIndex].imagePath != null && currentGenre[thumbnailTilelist.selectedIndex].artistName != null && currentGenre[thumbnailTilelist.selectedIndex].trackName != null && currentGenre[thumbnailTilelist.selectedIndex].albumName != null && nowViewingLabel.text != null && dayOfTheWeek != null)
                          insertIntoAllPlayedDBStatemement.sqlConnection = jukeDBConnection;
                          insertIntoAllPlayedDBStatemement.text = "INSERT INTO All_Played_Tracks(trackPath, imagePath, artistName, trackName, albumName, genre, dayPlayed) VALUES (\"" + currentGenre[thumbnailTilelist.selectedIndex].trackPath + "\", \"" + currentGenre[thumbnailTilelist.selectedIndex].imagePath + "\",\"" + currentGenre[thumbnailTilelist.selectedIndex].artistName + "\",\"" + currentGenre[thumbnailTilelist.selectedIndex].trackName + "\",\"" + currentGenre[thumbnailTilelist.selectedIndex].albumName + "\", \"" + nowViewingLabel.text + "\", \"" + dayOfTheWeek + "\")";
                          insertIntoAllPlayedDBStatemement.execute();
                          insertIntoTop50DBStatemement.sqlConnection = jukeDBConnection;
                          insertIntoTop50DBStatemement.text = "INSERT INTO Top50(trackPath, imagePath, artistName, trackName, albumName, genre) VALUES (\"" + currentGenre[thumbnailTilelist.selectedIndex].trackPath + "\", \"" + currentGenre[thumbnailTilelist.selectedIndex].imagePath + "\",\"" + currentGenre[thumbnailTilelist.selectedIndex].artistName + "\",\"" + currentGenre[thumbnailTilelist.selectedIndex].trackName + "\",\"" + currentGenre[thumbnailTilelist.selectedIndex].albumName + "\", \"" + nowViewingLabel.text + "\")";
                          insertIntoTop50DBStatemement.execute();
                catch(error:Error)
                     trace("<Error> " + error.message);
           else if(listTileListItemClicked == true)
                thumbnailTileListItemClicked = false;
                try
                     if(currentGenre[listTilelist.selectedIndex].trackPath != null && currentGenre[listTilelist.selectedIndex].imagePath != null && currentGenre[listTilelist.selectedIndex].artistName != null && currentGenre[listTilelist.selectedIndex].trackName != null && currentGenre[listTilelist.selectedIndex].albumName != null && nowViewingLabel.text != null && dayOfTheWeek != null)
                          //Problem found here with the below line....
                          insertIntoAllPlayedDBStatemement.text = "INSERT INTO All_Played_Tracks(trackPath, imagePath, artistName, trackName, albumName, genre, dayPlayed) VALUES (\"" + currentGenre[listTilelist.selectedIndex].trackPath + "\", \"" + currentGenre[listTilelist.selectedIndex].imagePath + "\",\"" + currentGenre[listTilelist.selectedIndex].artistName + "\",\"" + currentGenre[listTilelist.selectedIndex].trackName + "\",\"" + currentGenre[listTilelist.selectedIndex].albumName + "\", \"" + nowViewingLabel.text + "\", \"" + dayOfTheWeek + "\")";
                          //Alert.show("INSERT INTO All_Played_Tracks(trackPath, imagePath, artistName, trackName, albumName, genre, dayPlayed) VALUES (\"" + currentGenre[listTilelist.selectedIndex].trackPath + "\", \"" + currentGenre[listTilelist.selectedIndex].imagePath + "\",\"" + currentGenre[listTilelist.selectedIndex].artistName + "\",\"" + currentGenre[listTilelist.selectedIndex].trackName + "\",\"" + currentGenre[listTilelist.selectedIndex].albumName + "\", \"" + nowViewingLabel.text + "\", \"" + dayOfTheWeek + "\")");
                          insertIntoTop50DBStatemement.text = "INSERT INTO Top50(trackPath, imagePath, artistName, trackName, albumName, genre) VALUES (\"" + currentGenre[listTilelist.selectedIndex].trackPath + "\", \"" + currentGenre[listTilelist.selectedIndex].imagePath + "\",\"" + currentGenre[listTilelist.selectedIndex].artistName + "\",\"" + currentGenre[listTilelist.selectedIndex].trackName + "\",\"" + currentGenre[listTilelist.selectedIndex].albumName + "\", \"" + nowViewingLabel.text + "\")";
                catch(error:Error)
           else if(coverflowClicked == true)
                if(flowCurrentPage == 1)
                     try
                          if(currentGenre[flow.selectedIndex].trackPath != null && currentGenre[flow.selectedIndex].imagePath != null && currentGenre[flow.selectedIndex].artistName != null && currentGenre[flow.selectedIndex].trackName != null && currentGenre[flow.selectedIndex].albumName != null && nowViewingLabel.text != null && dayOfTheWeek != null)
                               insertIntoAllPlayedDBStatemement.text = "INSERT INTO All_Played_Tracks(trackPath, imagePath, artistName, trackName, albumName, genre, dayPlayed) VALUES (\"" + currentGenre[flow.selectedIndex].trackPath + "\", \"" + currentGenre[flow.selectedIndex].imagePath + "\",\"" + currentGenre[flow.selectedIndex].artistName + "\",\"" + currentGenre[flow.selectedIndex].trackName + "\",\"" + currentGenre[flow.selectedIndex].albumName + "\", \"" + nowViewingLabel.text + "\", \"" + dayOfTheWeek + "\")";
                               insertIntoTop50DBStatemement.text = "INSERT INTO Top50(trackPath, imagePath, artistName, trackName, albumName, genre) VALUES (\"" + currentGenre[flow.selectedIndex].trackPath + "\", \"" + currentGenre[flow.selectedIndex].imagePath + "\",\"" + currentGenre[flow.selectedIndex].artistName + "\",\"" + currentGenre[flow.selectedIndex].trackName + "\",\"" + currentGenre[flow.selectedIndex].albumName + "\", \"" + nowViewingLabel.text + "\")";
                     catch(error:Error)
                else
                     try
                          if(currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].trackPath != null && currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].imagePath != null && currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].artistName != null && currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].trackName != null && currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].albumName != null && nowViewingLabel.text != null && dayOfTheWeek != null)
                               insertIntoAllPlayedDBStatemement.text = "INSERT INTO All_Played_Tracks(trackPath, imagePath, artistName, trackName, albumName, genre, dayPlayed) VALUES (\"" + currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].trackPath + "\", \"" + currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].imagePath + "\",\"" + currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].artistName + "\",\"" + currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].trackName + "\",\"" + currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].albumName + "\", \"" + nowViewingLabel.text + "\", \"" + dayOfTheWeek + "\")";
                               insertIntoTop50DBStatemement.text = "INSERT INTO Top50(trackPath, imagePath, artistName, trackName, albumName, genre) VALUES (\"" + currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].trackPath + "\", \"" + currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].imagePath + "\",\"" + currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].artistName + "\",\"" + currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].trackName + "\",\"" + currentGenre[(flow.selectedIndex + ((flowCurrentPage - 1) * maxPics))].albumName + "\", \"" + nowViewingLabel.text + "\")";
                     catch(error:Error)
           else if(albumTrackClicked == true)
                try
                     if(currentGenre[albumTracksDatagrid.selectedIndex].trackPath != null && currentGenre[albumTracksDatagrid.selectedIndex].imagePath != null && currentGenre[albumTracksDatagrid.selectedIndex].artistName != null && currentGenre[albumTracksDatagrid.selectedIndex].trackName != null && currentGenre[albumTracksDatagrid.selectedIndex].albumName != null && nowViewingLabel.text != null && dayOfTheWeek != null)
                          insertIntoAllPlayedDBStatemement.text = "INSERT INTO All_Played_Tracks(trackPath, imagePath, artistName, trackName, albumName, genre, dayPlayed) VALUES (\"" + currentGenre[albumTracksDatagrid.selectedIndex].trackPath + "\", \"" + currentGenre[albumTracksDatagrid.selectedIndex].imagePath + "\",\"" + currentGenre[albumTracksDatagrid.selectedIndex].artistName + "\",\"" + currentGenre[albumTracksDatagrid.selectedIndex].trackName + "\",\"" + currentGenre[albumTracksDatagrid.selectedIndex].albumName + "\", \"" + nowViewingLabel.text + "\", \"" + dayOfTheWeek + "\")";
                          insertIntoTop50DBStatemement.text = "INSERT INTO Top50(trackPath, imagePath, artistName, trackName, albumName, genre) VALUES (\"" + currentGenre[albumTracksDatagrid.selectedIndex].trackPath + "\", \"" + currentGenre[albumTracksDatagrid.selectedIndex].imagePath + "\",\"" + currentGenre[albumTracksDatagrid.selectedIndex].artistName + "\",\"" + currentGenre[albumTracksDatagrid.selectedIndex].trackName + "\",\"" + currentGenre[albumTracksDatagrid.selectedIndex].albumName + "\", \"" + nowViewingLabel.text + "\")";
                catch(error:Error)
           else if(searchFlowItemClicked == true)
                try
                     if(searchTrackData[searchFlow.selectedIndex].trackPath != null && searchTrackData[searchFlow.selectedIndex].imagePath != null && searchTrackData[searchFlow.selectedIndex].artistName != null && searchTrackData[searchFlow.selectedIndex].trackName != null && searchTrackData[searchFlow.selectedIndex].albumName != null && searchTextInput.text != null && dayOfTheWeek != null)
                          insertIntoAllPlayedDBStatemement.text = "INSERT INTO All_Played_Tracks(trackPath, imagePath, artistName, trackName, albumName, genre, dayPlayed) VALUES (\"" + searchTrackData[searchFlow.selectedIndex].trackPath + "\", \"" + searchTrackData[searchFlow.selectedIndex].imagePath + "\",\"" + searchTrackData[searchFlow.selectedIndex].artistName + "\",\"" + searchTrackData[searchFlow.selectedIndex].trackName + "\",\"" + searchTrackData[searchFlow.selectedIndex].albumName + "\", \"search term = " + searchTextInput.text + "\", \"" + dayOfTheWeek + "\")";
                          insertIntoTop50DBStatemement.text = "INSERT INTO Top50(trackPath, imagePath, artistName, trackName, albumName, genre) VALUES (\"" + searchTrackData[searchFlow.selectedIndex].trackPath + "\", \"" + searchTrackData[searchFlow.selectedIndex].imagePath + "\",\"" + searchTrackData[searchFlow.selectedIndex].artistName + "\",\"" + searchTrackData[searchFlow.selectedIndex].trackName + "\",\"" + searchTrackData[searchFlow.selectedIndex].albumName + "\", \"search term = " + searchTextInput.text + "\")";
                catch(error:Error)
           else if(recommendedFlowItemClicked == true)
                insertIntoAllPlayedDBStatemement.text = "INSERT INTO All_Played_Tracks(trackPath, imagePath, artistName, trackName, albumName, genre, dayPlayed) VALUES (\"" + searchTrackData[recommendedFlow.selectedIndex].trackPath + "\", \"" + searchTrackData[recommendedFlow.selectedIndex].imagePath + "\",\"" + searchTrackData[recommendedFlow.selectedIndex].artistName + "\",\"" + searchTrackData[recommendedFlow.selectedIndex].trackName + "\",\"" + searchTrackData[recommendedFlow.selectedIndex].albumName + "\", \"search term = " + "Now Playing/Recommended" + "\", \"" + dayOfTheWeek + "\")";
                insertIntoTop50DBStatemement.text = "INSERT INTO Top50(trackPath, imagePath, artistName, trackName, albumName, genre) VALUES (\"" + searchTrackData[recommendedFlow.selectedIndex].trackPath + "\", \"" + searchTrackData[recommendedFlow.selectedIndex].imagePath + "\",\"" + searchTrackData[recommendedFlow.selectedIndex].artistName + "\",\"" + searchTrackData[recommendedFlow.selectedIndex].trackName + "\",\"" + searchTrackData[recommendedFlow.selectedIndex].albumName + "\", \"search term = " + "Now Playing/Recommended" + "\")";
      Flexchief
