0 Replies Latest reply: Nov 17, 2009 3:29 PM by rfrishbe RSS
    [svn:fx-trunk] 11913: Changing VolumeBar.closeDropDown() back to the way it was.
    rfrishbe Community Member
      Revision: 11913
      Revision: 11913
      Author:   rfrishbe@adobe.com
      Date:     2009-11-17 15:29:29 -0800 (Tue, 17 Nov 2009)
      Log Message:
      Changing VolumeBar.closeDropDown() back to the way it was.  Even though we ignore the commit:Boolean parameter, some subclass may want this behavior if they add key-interaction support to volume bar, and their volume bar doesn't pop up on rollOver.
      Also changing ASDoc "@private" protected methods to mx_internal because protected methods should either be documented or not made protected.
      QE notes: -
      Doc notes: -
      Bugs: -
      Reviewer: Jason and I discussed them
      Tests run: checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoPlayer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoPlayer2.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/mediaClasses/VolumeBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/DropDownCont roller.as
