• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Formatting a string?
New Here ,
Jul 15, 2008 Jul 15, 2008
I'm trying to format a string for a query using cfscript. Instead of using &'s to concatenate a string, is there a method in CF that is similar to .NET's String.Format method or php's sprintf function? Thanks.
Ryan
TOPICS
Advanced techniques
Views
295
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
I don't know what those functions do, but if you don't like the concat operator, you can use octothorps inside quotes for the variable part of your string.
Since you mentioned that you will eventually use this string inside your query, the PreserveSingleQuotes function might be relevent.
Votes
Translate
Translate
Report
Report
Engaged ,
LATEST
You can just use the # symbols inside quotes, e.g.
<cfset fName = "Simon">
<cfset lName = "Baynes">
<cfset withAnds = fName & " " & lName>
<cfset withoutAnds = "#fName# #lName#">
Those produce the same results.
Also you can use Java.
<cfset oBuilder = createObject("java", "java.lang.StringBuilder").init()>
<cfset oBuilder.append(fName)>
<cfset oBuilder.append(" ")>
<cfset oBuilder.append(lName)>
<cfset javaWay = oBuilder.toString()>
If you are doing lots of concatenation then I recommend the java option, because Strings are immutable. This means that once assigned they cannot be changed, so when you do a concatenation you are actually creating a new object in memory. Which is what the StringBuilder overcomes, so if you are doing appending in a loop for example this will be quicker and less memory intesive.
HTH
Votes
Translate
Translate
Report
Report
Resources
Documentation
