0 Replies Latest reply on Nov 17, 2009 4:01 PM by GordonSmith
    [svn:fx-trunk] 11915: Tweaked metadata for two Spark text styles.
    GordonSmith Level 4
      Revision: 11915
      Revision: 11915
      Author:   gosmith@adobe.com
      Date:     2009-11-17 16:01:12 -0800 (Tue, 17 Nov 2009)
      Log Message:
      The 'baselineShift' style should not declare any enumerated values, because this makes the MXML compiler not allow numeric values like baselineShift="10".
      The 'direction' style should not have "inherit" in its enumeration. TLF FlowElements have formatting properties which can be set to an "inherit" value, but this does not make sense at the level of Flex components and their CSS styles. Flex styles either inherit or don't and you can't specify them to do the other. The 'direction' style is inherently inheriting due to inherit="yes".
      QE notes: None
      Doc notes: None
      Bugs: SDK-23929
      Reviewer: Evtim
      Tests run: ant checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23929
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/styles/metadata/BasicInheritingTextSty les.as
