2 Replies Latest reply on Nov 18, 2009 5:56 AM by Gregory Lafrance
    Assign data field in a data grid based on a condition
    appdevs Level 1
      I have a n XMLList called as resultA and it looks like this
      <cmpName srcVariable="aft_panic" srcValue= "8" tgtVariable ="aft_panic" tgtValue ="7" >
      <cmpName srcVariable="Missing"   srcValue= "Missing" tgtVariable ="maxphys" tgtValue ="2400">
      I have used this XMLList to create a data grid and it works fine:
      <mx:DataGrid id="dg3" dataProvider="{resultA1}" >
             <mx:columns >
         <mx:DataGridColumn id = "col1" dataField="@srcVariable" headerText="EtcSystem Variable"/>
         <mx:DataGridColumn id = "col2" dataField="@srcValue" headerText="{server1Display}"/>
         <mx:DataGridColumn id = "col3" dataField="@tgtValue" headerText="{server2Display}"/>
             </mx:columns>
      </mx:DataGrid>
      Now , I need to make a small change to the first column dataField:
      The first column in the data grid should have the @srcVariable data.But if the @srcVariable = "Missing" as in the second row in the XMLList above, the @tgtVariable should become the first column data.
      Something like this :
      if(resultA.@srcVariable == "Missing"){
         dg3.col1.dataField = resultA.@tgtVariable
      }else{
         dg3.col1.dataField = resultA.@srcVariable
      Can anyone let me know how i can achieve this?
        • 2. Re: Assign data field in a data grid based on a condition
          Gregory Lafrance Level 6
          If this post answers your question or helps, please mark it as such.
          Here is the labelFunction in action:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
            <mx:Script>
              <![CDATA[
                private function myLabFunc(item:Object, dgc:DataGridColumn):String{
                  var retStr:String;
                  if(item.@srcVariable == "Missing"){
                    retStr = item.@tgtVariable;
                  }else{
                    retStr = item.@srcVariable;
                  return retStr;
            </mx:Script>
            <mx:XMLList id="resultA1" xmlns="">
                tgtVariable ="aft_panic" tgtValue ="7" />
                tgtVariable ="maxphys" tgtValue ="2400"/>
            </mx:XMLList>
            <mx:DataGrid id="dg3" dataProvider="{resultA1}" width="200">
              <mx:columns>
                <mx:DataGridColumn id = "col1" labelFunction="myLabFunc" width="150"
              </mx:columns>
            </mx:DataGrid>
          </mx:Application>
