6 Replies Latest reply on Nov 18, 2009 11:47 PM by harihisu
    OOP : C++ vs AS
    iamfuric Level 2
      All
      As most of you know , the C++ programm below otputs string "I'm A", (which i can fully understand):
      class A{
      public:
      A(){
        print();
      virtual void print(){
        printf("I'm A\n");
      class B:public A{
      public :
        printf("I'm B\n");
      int _tmain(int argc, _TCHAR* argv[])
      A* bPtr = new B;
      delete bPtr;
      return 0;
      This is not true for the AS alternative : (output is "I'm B")
      public class A
        public function A()
         print();
        public function print():void{
         trace("I'm A");
      public class B extends A
        public function B()
         super();
        override public function print():void{
         trace("I'm B");
        var a:A = new B();
      How AS knows about B instance while creation of it's parent object instance ?
      Gurus,please clarify
        • 1. Re: OOP : C++ vs AS
          harihisu Level 2
          IMO, that because AS3 has a different mechanism of creating an instance of a class.
          In C++, you cannot initialize a variable when declare it inside a class such as:
          class A {
          public:
               int i = 1;
               A() {
          But you can do that with AS3, and that initialization will be implemented first. You can trace the process by using trace function like this:
          public class A {
               var i:int = 1;
               trace( 1 );
               public function A() {
                    trace( 2 );
               trace( 3 );
          // output 1 then 3 then 2
          Beside, a function in AS3 is a special kind of variable, instance of class Function. Then, the AVM will initialize the function BEFORE call the constructor. That means function print of class B had the value { trace("I'm B"); } BEFORE we call print() via A's constructor. In this moment, the constructor will refer to the latest print function, then why it print out "I'm B".
          Hope it helps.
          • 2. Re: OOP : C++ vs AS
            iamfuric Level 2
            Thanks for replay
            Digging dipper, it turns out, there is no way to call parent overriden  function explicitly:
            Looks like  the function is "hard" overriden - no reference to the parent implementation (aka C++ __vfptr).
            AVM  simply instantiatres the functions and then executes them in context of {this} object instance.
            • 3. Re: OOP : C++ vs AS
              EgorKDie Level 2
              you can get access to the overridden method...
              super.print() will call it.
              • 4. Re: OOP : C++ vs AS
                harihisu Level 2
                Yes,
                Just like Java, all method (function) of a class is "virtual". And like EgorKDie said, "super" is superb in this case
                • 5. Re: OOP : C++ vs AS
                  iamfuric Level 2
                  I meant "from outside".
                  In C++ you can :
                  B b;
                  b.print(); // I'm B
                  ((A)b).print(); // I'm A
                  but in AS:
                  var a:A = new B();
                  a.print(); // I'm B
                  (a as A).print(); // I'm still  B
                  • 6. Re: OOP : C++ vs AS
                    harihisu Level 2
                    As I said before, Actionscript 3 is Java-like.
                    Refer to the first answer in this link:
                    http://stackoverflow.com/questions/1032847/can-java-call-parent-overridden-method-in-other -objects-but-not-subtype
                    , call superclass method outside the subclass is prohibited due to encapsulation violation.  IMO, C++ is not a pure OOP (thus it doesn't fully support OOP characteristics), that's why you can easily call parent class' method via casting.
