0 Replies Latest reply on Nov 18, 2009 4:46 AM by Darrell Loverin
    [svn:fx-trunk] 11926: Fix 3. 0 compatiblity-version bug with generated styles.
    Darrell Loverin Level 4
      Revision: 11926
      Revision: 11926
      Author:   dloverin@adobe.com
      Date:     2009-11-18 04:46:03 -0800 (Wed, 18 Nov 2009)
      Log Message:
      Fix 3.0 compatiblity-version bug with generated styles.
      src/java/flex2/compiler/common/CompilerConfiguration.java
         Turn ?\226?\128?\147isloate-styles off in 3.0 compatibility mode. This flag also turns on the hidden option ?\226?\128?\147allow-duplicate-default-style-declarations which is what fixes the bug.
      src/java/flex2/compiler/css/StyleDef.vm
         Changed a tab to spaces.
      QE notes: None.
      Doc notes: None.
      Bugs: SDK-24259
      Reviewer: Peter
      Tests run: checkintests
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24259
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.vm
