0 Replies Latest reply on Nov 18, 2009 5:52 AM by Carol L. Frampton
    [svn:fx-trunk] 11928: TLF Build 554.
    Carol L. Frampton Level 2
      Revision: 11928
      Revision: 11928
      Author:   cframpto@adobe.com
      Date:     2009-11-18 05:52:33 -0800 (Wed, 18 Nov 2009)
      Log Message:
      TLF Build 554.  First fix needed to complete RET api work to remove interactionManager dependency.
      Build 554
      • Fix 2484989 FlowOperations Should Not Assume an interactionManager
      • Fix 2418508 Pending Operations Are not Flushed When Next Operation is Called Directly
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/libs/textLayout.swc
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/ContainerCo ntroller.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/EditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/SelectionManager .as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/IConfigurati on.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/CutOperati on.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/DeleteText Operation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/InsertInli neGraphicOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/InsertText Operation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/PasteOpera tion.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/SplitParag raphOperation.as
      Added Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.554.swf
      Removed Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.553.swf
