0 Replies Latest reply on Nov 18, 2009 6:10 AM by mraccess1977
    [svn:fx-trunk] 11930: Update of accessibility implementation to allow for case of null titleDisplay  (title).
    mraccess1977 Level 1
      Revision: 11930
      Revision: 11930
      Author:   jon.avila@ssbbartgroup.com
      Date:     2009-11-18 06:10:40 -0800 (Wed, 18 Nov 2009)
      Log Message:
      Update of accessibility implementation to allow for case of null titleDisplay (title).  If there is no title then no accImpl will be created but accessibility properties can still be set on the component.  Also added code to set the tabIndex of the titleDisplay to the tabIndex of the Panel if one exists.  This allows the title of the panel to appear in reading order as assigned by the tabIndex.
      QE notes: none
      Doc notes: none
      Bugs: n/a
      Reviewer: Gordon
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/accessibility/PanelAccImpl.as
