0 Replies Latest reply on Nov 18, 2009 7:01 AM by Carol L. Frampton
    [svn:fx-trunk] 11934: Remove dependencies RichEditableText api calls had on using an interactionManager .
    Carol L. Frampton Level 2
      Revision: 11934
      Revision: 11934
      Author:   cframpto@adobe.com
      Date:     2009-11-18 07:01:08 -0800 (Wed, 18 Nov 2009)
      Log Message:
      Remove dependencies RichEditableText api calls had on using an interactionManager.  API calls can be done regardless of the values of editable and selectable which just apply to interactive editing.
      The api calls are: insertText, appendText, selectRange, selectAll, setFormatOfRange, getFormatOfRange.  The first 4 methods can change the selection and when that occurs, a selectionChange event will be dispatched.
      The editingMode should not be changed any event handler while in the middle of a text operation.  This includes the selectionChange event.
      I may make a few more tweaks to this code as I continue to test and find edge conditions.
      QE notes:
      Doc notes: editingMode should not be changed by any event handler while in the middle of a text operation
      Bugs: SDK-23638
      Reviewer: Gordon
      Tests run: checkintests, TextArea, TextInput, NumericStepper, ComboBox
      Is noteworthy for integration: yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23638
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichEditableText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/RichEditable TextContainerManager.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SkinnableTex tBase.as
