2 Replies Latest reply on Nov 18, 2009 9:31 AM by manofspirit
    removeChildAt with removedEffect causing problem
    manofspirit Level 1
      Hi
      My application removes CHOSEN children in a container using a loop.
      my application crashes if removedEffect is enable in children.
      Here is the code for removing
      var numberOfChildren:Number = nodesArea.numChildren;
      for(var i:Number = (numberOfChildren-1) ; i >= 0; i--){
           if((nodesArea.getChildAt(i) as Node).isGud == true){
                nodesArea.removeChildAt(i);
      Please download and test the sample application yourself to experience the problem.
        • 1. Re: removeChildAt with removedEffect causing problem
          RK... Level 3
          There is a synchronization issue that occurs while the removedEffect is playing. So I've slightly modified your code. Added hideEffect instead of removedEffect. In main application a timer is added to remove the invisible nodes. Hope this will help you
          Node.mxml
          <mx:Canvas moveEffect="Move" showEffect="Fade" hideEffect="Fade" xmlns:mx="http://www.adobe.com/2006/mxml" width="100" height="100" backgroundColor="#B6A3FF">
          <mx:Script>
          <![CDATA[
          public var isGud:Boolean = true;
          </mx:Script>
          </mx:Canvas>
          RemoveChildProblem.mxml
          private var _timer: Timer = null;
          private function removeChildren():void{
          if (!_timer) {
          _timer = new Timer(550);
          //Add listener to update progress bar
                      _timer.addEventListener(TimerEvent.TIMER, removeHandler, false, 0, true);
                      //Start timer
                      _timer.start();
          if((nodesArea.getChildAt(i) as Node).isGud){
          (nodesArea.getChildAt(i) as Node).visible = false;
          private function removeHandler(event: TimerEvent): void {
          if(!(nodesArea.getChildAt(i) as Node).visible){
          _timer.stop();
