3 Replies Latest reply on Nov 18, 2009 11:42 AM by sudhirm-rRcgag
    Code introspection / PHP
    Stormgully
      Hello,
      I'm fairly new to the flex framework so please forgive any ignornace in my question. I'm having issues getting the code introspection working.
      I'm running PHP 5.9.2 on window 2008 w/ IIS 7.0 and my database platform is MS SQL 2005. At this point all I'm trying to do is use the "generate a code sample" option and I have not had any luck thus far. I'm getting the following error message when clicking connect:
      Warning: require_once(Zend/Loader/Autoloader.php) [function.require-once]: failed to open stream: No such file or directory in D:\inetpub\wwwroot\dev\vacation\tempgateway.php on line 27
      Fatal error: require_once() [function.require]: Failed opening required 'Zend/Loader/Autoloader.php' (include_path='.;D:\php\includes;D:\inetpub\wwwroot/ZendFramework/library') in D:\inetpub\wwwroot\dev\vacation\tempgateway.php on line 27
      The ZendFramework folder and amf_config.ini both reside in the root application folder.
      Any help would be greatly apprecaited.
      Thanks!
