0 Replies Latest reply on Nov 18, 2009 9:33 AM by Darrell Loverin
    [svn:fx-trunk] 11942: StyleManager fixes.
    Darrell Loverin Level 4
      Revision: 11942
      Revision: 11942
      Author:   dloverin@adobe.com
      Date:     2009-11-18 09:33:13 -0800 (Wed, 18 Nov 2009)
      Log Message:
      StyleManager fixes.
      Stop using the styleManager property in a constructor.
      framework/src/mx/containers/DividedBox.as
      framework/src/mx/containers/Form.as
      framework/src/mx/controls/ButtonBar.as
      Cache inheriting styles. Also made static arrays in StyleManagerImpl per-instance.
      framework/src/mx/events/FlexChangeEvent.as
      framework/src/mx/styles/StyleManagerImpl.as
      Remove static StyleManager methods that were new to Flex 4 (qualifiedTypeSelectors property, getStyleDeclarations(), hasAdvancedSelectors(), hasPseudoCondition()).
      framework/src/mx/styles/StyleManager.as
      Update copyright.
      framework/src/mx/styles/CSSMergedStyleDeclaration.as
      QE notes: None.
      Doc notes: None.
      Bugs: SDK-24215
      Reviewer: Alex
      Tests run: checkintests, containers/DividedBox, containers/form, components/ButtonBar, Managers/StyleManager, PerModuleStyleManager
      Is noteworthy for integration: yes - StyleManager performance improvement
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24215
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/DividedBox.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Form.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ButtonBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/events/FlexChangeEvent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/CSSMergedStyleDeclaration.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManagerImpl.as
