12 Replies Latest reply on Nov 18, 2008 11:31 AM by DC_Eric2
    linking to a PDF - problem
    Level 7
      My first attempt to link to a PDF. Not working. Followed the directions
      on DW support page. This PDF was not created by me. Sent by the
      magazine. Is that the problem? The PDF has been uploaded to the server
      and is in the files.
      Liz
        • 1. Re: linking to a PDF - problem
          Level 7
          > Liz
          Do you want the end-user to be able to download the pdf file to their
          desktop? If so you need to zip the pdf and upload the zip file to the
          server and link to it.
          • 2. Re: linking to a PDF - problem
            Level 7
            Osgood wrote:
            >> directions on DW support page. This PDF was not created by me. Sent by
            >> the magazine. Is that the problem? The PDF has been uploaded to the
            >> server and is in the files.
            >> Liz
            Do I need to zip it in any case? Is that why the link is not working?
            Liz
            • 3. Re: linking to a PDF - problem
              Level 7
              Liz wrote:
              >>> by the magazine. Is that the problem? The PDF has been uploaded to
              >>> the server and is in the files.
              >>> Liz
              > Liz
              It should work without being zipped but why not try and zip it and see
              what happens.
              Try linking to another pdf and see if that works to eliminate the
              possibility that the pdf is corrupt in some way.
              • 4. Re: linking to a PDF - problem
                Level 7
                Sorry. I goofed! forgot to give you the URL of the page with the
                problem: http://seascapesartgallery.com/artist.htm
                Liz
                >>> Liz
                > Liz
                • 5. Re: linking to a PDF - problem
                  bregent Most Valuable Participant
                  I don't see a link to any pdf on that page. Can you explain your problem in more detail?
                  • 6. Re: linking to a PDF - problem
                    Level 7
                    The pdf file is not where the links says it is?
                    http://seascapesartgallery.com/kersteinarticleweb.pdf
                    According to the link above it should be directly within the site root
                    folder...so where is it?
                    >>>> Liz
                    >> Liz
                    • 7. Re: linking to a PDF - problem
                      Also, there is no reason at all for you to be using absolute positioning on that page. See what happens when the visitor has their text sized differently?
                      • 8. Re: linking to a PDF - problem
                        Level 7
                        It is in the root file. I uploaded it with the page.
                        Liz
                        >>>>> Liz
                        >>>> their desktop? If so you need to zip the pdf and upload the zip file
                        >>>> to the server and link to it.
                        >>> Liz
                        • 9. Re: linking to a PDF - problem
                          Have you verified that by viewing the remote files?
                          • 10. Re: linking to a PDF - problem
                            wendyskains
                            A silly question maybe, but are you sure the name of the PDF and the link are the same?
                            • 11. Re: linking to a PDF - problem
                              When I click that link, I get a file not found error
                              About name... do you maybe have Kersteinarticleweb.pdf as the actual name?
                              Or, any other capital/lower case letter differences? Any old use of letters will work on your computer (well... Windoze, I don't know about a Linux box) but you must have ExAcTlY correct upper and lower case letters in a link and file name
                              • 12. Re: linking to a PDF - problem
                                DC_Eric2 Level 1
                                You link a pdf the same way you link any other document to a web site. The page you listed has no links to pdf file
                                What is the page / URL of the page that is trying to link to a pdf and what is the text on that page that has the link applied to it?
