3 Replies Latest reply: Nov 26, 2009 9:37 AM by paulk07 RSS
    Unique Numbering/Add Subforms
    meem23 Community Member
      Can you tell me if this is possible to do in LC Designer 7.1.
      I have a form that is 8.5 x 5.5 and there are two of these forms on a 8.5 x 11 page.  On each form there is a unique number and it is numbered consecutively, however, the numbering is offset by the number of copies needed.  For instance, if I need 200 forms, the number on form 1 would be 001 and on the same page, form 2 would be number 101.  The next page would be 002 for form 1 and 102 for form 2 and so on.
      I want to be able to enter a starting number into a field and enter a quantity into another field.  The starting number will be the number on form 1 and the quantity will trigger the amount of forms needed - in the order I described above.
      Attached is a rough sample.
      If this is at all possible, I would appreciate the help.
      Thanks!
        • 1. Re: Unique Numbering/Add Subforms
          paulk07 Community Member
          Wow.  I'm no programmer but I've been researching this.  With no responses, there maybe no solution.  There is a script to count the # of instances of adding a subform:
          BodyPage1.RepeatingSubform.instanceManager.count
          Also a script to add page numbers:
          this.rawValue = xfa.layout.page(this);
          But I don't think that will serve your purpose.  I'm playing with these to see if it can work.
          • 2. Re: Unique Numbering/Add Subforms
            I found a script that worked with the Quantity field (see below), however, I'm still stumped on how to do the unique numbering.
            var numField = this.rawValue;
            var count = xfa.form.SF0273.Ticket.Page1.Form1.all.length
            var t;
            var r=0;
            if(count > 1){
            for(t = 0; t < count-1; t++){
            xfa.form.SF0273.Ticket.Page1.Form1.instanceManager.removeInstance(1);
            for(t = 0; t<=numField -2; t++){
            xfa.form.SF0273.Ticket.Page1.Form1.instanceManager.addInstance(1);
            Thanks for your response and help.
            • 3. Re: Unique Numbering/Add Subforms
              I haven't given up.  Posted this elsewhere in hopes of a solution.  I'm
              thinking it can be done.
