Revision: 11954
Revision: 11954
Author: klin@adobe.com
Date: 2009-11-18 13:21:21 -0800 (Wed, 18 Nov 2009)
Log Message:
Fix for https://bugs.adobe.com/jira/browse/SDK-24177. ScrollBar and Slider implementations were not taking into account the case of when the thumb and track had different parents. I've added logic to convert the position from the track's coordinates to global coordinates and then to the thumb's parent's coordinates.
QE notes: No
Doc notes: No
Bugs: SDK-24177
Reviewer: Glenn
Tests run: checkintests, ScrollBar, Slider
Is noteworthy for integration: Yes, ScrollBars should work correctly if thumb and track are in separate groups
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-24177
Modified Paths:
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/HScrollBar.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/HSlider.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VScrollBar.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VSlider.as
