3 Replies Latest reply on Nov 19, 2009 4:58 AM by $Nith$
    Help needed with forms
    simebradley
      Hi I have created a form for a client in LiveCycle ES and they want the form to have the following actions:
      1. Client A will fill the form in and send to the Client B.
      2. The form needs to have a password on so Client B can not be alter it.
      3. Client B then needs to be able to send the form back to two email address with the submit button to Client A and to a central PC when the database will be stored.
      Thanks!
        • 1. Re: Help needed with forms
          $Nith$ Level 4
          "2. The form needs to have a password on so Client B can not be alter it."
            This means the client B can read the PDF but cannot alter it. Am I correct?
            If so you can either:
                     1. Make all fields read-only using scripting
                     2. Flatten the PDF so that it cannot be altered anymore
                     3. Apply Usage Rights and set password so that the client B can read the PDF only supplying the correct password.
          "3. Client B then needs to be able to send the form back to two email address"
               It is as simple as you route the task back to client A and the central PC.
          Hope this will help you.
          Nith
          • 2. Re: Help needed with forms
            simebradley Level 1
            Hi $Nith$
            thanks for your reply,
            I have managed to get hold of a script and alter it so it sends to two email address when you hit the email button.
            When I set a password in the form properties it will not let me distribute the form.
            What I need the form to do is client A fills in the form, then sends it to client B, client B looks at the data on the form (but is unable to change the data) then sends the form back to the two different email address (which will be client A's & the central PC with the database on). Then the database PC will open the form and be able to create a database of the forms.
            • 3. Re: Help needed with forms
              $Nith$ Level 4
              So you can flatten your pdf using transformPDF activity.
              Nith
