0 Replies Latest reply on Nov 19, 2009 7:38 PM by PChiranjeevi
    Datagrid Checkbox item renderer Issue.
    PChiranjeevi Level 1
      Hi There
      Recently I faced a  requirement to have a checkbox inside a datagrid where I need to develop a music module with playlist management for ADOBE AIR based application.
      For this I have searched and found a source to use Datagrid and Checkbox components which overrides some inbuild methods to give the required result..
      But Finally I ended with one strange issue
      When the check box is placed in the datagrid at 0 column index it works firne but if we place at any index ( I need it to be last colum ) the checkbox is not updating the display.
      Source Flex Air project attached.
      From the sample... While clicking on a row the left column checkbox is getting updated but Right remains same... when you scroll the Datagrid then the checkboxes are getting update when they are redrawn. I didn't found where to call the redraw for the right checkbox column.
      Cany any one faced this strange issue. and found any solution ?????
      If the Logic what I am following for a Playlist module is not good one then suggest if you guys know any other mechanism to develop a playlist management with datagrid and Checkboxes.
      Message was edited by: ChintuBabu
