7 Replies Latest reply on Nov 21, 2009 7:37 AM by kglad
    Password?!
    Schabloah
      How do i do a password thingy. SO its a little text box and you need to write the right word to go to next page?!
      I use AS 2.
        • 1. Re: Password?!
          textfields have a password property that you can enable.
          where you store and, how you check the password depends on your need for security.  it the password doesn't need to be secure, the easiest thing to do is to store the correct password in the swf and check it against the user's input:
          passwordTF.password = true;
          var notsosecretpassword:String = "zxc924u";
          submitbutton.onRelease=function(){
          if(passwordTF.text==notsosecretpassword){
          // do whatever.
          } else {
          // do whatever else
          • 2. Re: Password?!
            Schabloah Level 1
            So i make a dynamisk text... and put the code in the frame?!
            • 3. Re: Password?!
              you don't have to do that.  it's just the easiest and least secure way to use a password in flash.
              • 4. Re: Password?!
                Schabloah Level 1
                DOnt work... maybe its better if i explain more what i want to do:
                You write something in a text box and press enter. Is it the right word you´ll go to next frame...if its wrong?Then  Nothing happens..
                • 5. Re: Password?!
                  if the code i gave doesn't work for you it's because of something you're doing wrong.  for example, did you code for the enter key to execute the code i gave?
                  • 6. Re: Password?!
                    Schabloah Level 1
                    What am i do
                    ing wrong? I:
                    1.Make a dynamik text box.
                    2.past the code into the frame.
                    What is wrong? Plz help!
                    • 7. Re: Password?!
                      3.  create a submit button
                      4.  assign it an instance name that matches the name used in the code
                      5.  replace the comments with actions
                      6.  test by entering text and clicking the submit button
