0 Replies Latest reply on Nov 19, 2009 7:37 AM by jmurphy67
    [svn:fx-trunk] 11984: Merged 3.x revisions 11672,11898,11927,11952 -> trunk
    jmurphy67 Level 1
      Revision: 11984
      Revision: 11984
      Author:   jimurphy@adobe.com
      Date:     2009-11-19 07:30:34 -0800 (Thu, 19 Nov 2009)
      Log Message:
        r11672 | clucier@adobe.com | 2009-11-11 17:07:26 -0500 (Wed, 11 Nov 2009) | 10 lines
        Bugs: SDK-23661
        r11898 | clucier@adobe.com | 2009-11-17 12:38:44 -0500 (Tue, 17 Nov 2009) | 10 lines
        Bugs: SDK-22721
        r11927 | clucier@adobe.com | 2009-11-18 08:42:28 -0500 (Wed, 18 Nov 2009) | 10 lines
        Bugs: SDK-16241
        r11952 | clucier@adobe.com | 2009-11-18 15:42:08 -0500 (Wed, 18 Nov 2009) | 10 lines
        Bugs: SDK-15988
      The majority of files in this change list are svn property changes - removing the svn:mergeinfo property
      The following paths are the actual changes from 3.x that were merged:
      frameworks/projects/rpc/src/mx/rpc/soap/SOAPDecoder.as
      frameworks/projects/framework/src/mx/formatters/NumberFormatter.as
      frameworks/projects/framework/src/mx/formatters/NumberBase.as
      frameworks/projects/airframework/src/mx/managers/NativeDragManagerImpl.as
      frameworks/projects/framework/src/mx/controls/ColorPicker.as
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23661
          http://bugs.adobe.com/jira/browse/SDK-22721
          http://bugs.adobe.com/jira/browse/SDK-16241
          http://bugs.adobe.com/jira/browse/SDK-15988
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/managers/NativeDragManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ColorPicker.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/formatters/NumberBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/formatters/NumberFormatter.as
          flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/soap/SOAPDecoder.as
      Property Changed:
          flex/sdk/trunk/
          flex/sdk/trunk/checkin-note-template.txt
          flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/UIComponentAccProps.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/collections/AsyncListView.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ILayoutElement.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ISWFLoader.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IVisualElement.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IVisualElementContainer.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/SecurityUtil.as
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/graphics/
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/primitives/
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/styles/
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/PopUpAnchor.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichEditableText.png
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoPlayer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoPlayer.png
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoPlayer2.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/DisplayLayer .as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/RichEditable TextContainerManager.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/events/DisplayLayerObjectExistenceEven t.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/events/ElementExistenceEvent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/BasicLayout.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/ColumnAlign.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/HorizontalAlign.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/HorizontalLayout.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/RowAlign.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/TileLayout.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/TileOrientation.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/VerticalAlign.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/VerticalLayout.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/supportClasses/Block.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/supportClasses/LayoutBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/supportClasses/LayoutElementHe lper.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/supportClasses/LinearLayoutVec tor.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VideoPlayerSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VideoPlayerSkin2.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/PlayPa useButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/styles/metadata/AdvancedInheritingText Styles.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/styles/metadata/BasicInheritingTextSty les.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/styles/metadata/BasicNonInheritingText Styles.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexFXG2SWFTranscoder.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGConstants.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/AbstractFXGNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/AbstractShapeNode.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/BitmapGraphicNode.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/DefinitionNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/DelegateNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/EllipseNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/FillNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/FilterNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GradientEntryNode.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GraphicContentNode.ja va
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GraphicContext.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GraphicNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GroupDefinitionNode.j ava
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GroupNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/LibraryNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/LineNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/MaskPropertyNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/MaskableNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/MaskingNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/PathNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/PlaceObjectNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/RectNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/ScalableGradientNode. java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/StrokeNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/TextGraphicNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/TextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/TransformNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/fills/AbstractFillNod e.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/fills/BitmapFillNode. java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/fills/LinearGradientF illNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/fills/RadialGradientF illNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/fills/SolidColorFillN ode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/AbstractFilte rNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/BevelFilterNo de.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/BlurFilterNod e.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/ColorMatrixFi lterNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/DropShadowFil terNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/GlowFilterNod e.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/GradientBevel FilterNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/GradientGlowF ilterNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/strokes/AbstractStrok eNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/strokes/LinearGradien tStrokeNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/strokes/RadialGradien tStrokeNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/strokes/SolidColorStr okeNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/text/AbstractCharacte rTextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/text/AbstractTextNode .java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/text/BRNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/text/ParagraphNode.ja va
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/text/SpanNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/transforms/AbstractTr ansformNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/transforms/ColorTrans formNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/transforms/MatrixNode .java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/BevelType.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/BlendMode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/Caps.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/InterpolationMe thod.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/Joints.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/Kerning.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/LineBreak.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/MaskType.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/ScaleMode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/ScalingGrid.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/SpreadMethod.ja va
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/WhiteSpaceColla pse.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/Winding.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/sax/FXGSAXScanner.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/ImageHelper.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/ShapeHelper.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/TypeHelper.java
          flex/sdk/trunk/modules/webtier/j2ee/bootstrap/
          flex/sdk/trunk/modules/webtier/j2ee/build.properties
          flex/sdk/trunk/modules/webtier/j2ee/build.xml
          flex/sdk/trunk/modules/webtier/j2ee/coldfusion/
          flex/sdk/trunk/modules/webtier/j2ee/lib/
          flex/sdk/trunk/modules/webtier/j2ee/local.properties
          flex/sdk/trunk/modules/webtier/j2ee/readme.txt
          flex/sdk/trunk/modules/webtier/j2ee/servlet/
          flex/sdk/trunk/modules/webtier/j2ee/taglib/
