quote:
Originally posted by: MergeThis
The ost likely things that come to mind:
* You're working over a network (bad).
* You're working in a topic that's assigned to a template or master (whatever they call it in RH7).
* You have style info inside the HEAD section of the topic.
* The style assigned to the text in the table rows is superceding the table cell alignment.
quote:
Originally posted by: JaredHess
You might want to try editing it outside of RH. For example, edit it inside a text editor and then reload the topic inside RH to see if the change sticks. Sometimes RH just needs a kick to get it jump started.
In your reply, please click Attach Code and paste everything in one of these puppies, from <!doctype...> up to (and including) <body...>.
In addition, the ../ indicates that the CSS file is one level above this topic's location. Is that the case?
