0 Replies Latest reply on Nov 19, 2009 2:38 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 12016: Fix MXMLC compilers don't honor bitmapfill x, y translation http://bugs.adobe.com/jira/browse/SDK-24272
      Revision: 12016
      Revision: 12016
      Author:   egeorgie@adobe.com
      Date:     2009-11-19 14:37:57 -0800 (Thu, 19 Nov 2009)
      Log Message:
      Fix MXMLC compilers don't honor bitmapfill x,y translation http://bugs.adobe.com/jira/browse/SDK-24272
      Problems fixed:
      1. BitmapFill - Explicit matrix was offset relative to the natural bounds top left, should ignore natural bounds.
      2. BitmapFill - Explicit x/y overrides were applied relative to the natural bounds top-left, should be applied relative to (0,0) - test case in this bug.
      3. BitmapFill - Explicit scaleX/scaleY were always combined with the default fill transform (problem for fillMode="scale").
      4. Path - Stroke bounds for path only were wrong - the fill bounds were used instead.
      QE notes: Add additional tests for problems described above.
      Doc notes: None
      Bugs: SDK-24272
      Reviewer: Jason
      Tests run: checkintests + mustella cyclone
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/BitmapFill.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/LinearGradient.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/LinearGradientStroke.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/RadialGradient.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/RadialGradientStroke.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/Path.as
