1 Reply Latest reply on Nov 20, 2009 11:25 AM by tzeng
    AIR Application Install Location
    silentryan Level 1
      I have an application that has a tomcat backend and an AIR UI. I have a bat file that starts the tomcat server and I would also like that bat file to start the AIR UI so that a user does not have to click two icons to run the application. I want to be able to start the AIR application in the same bat file but to be able to do that I need to know where it is installed. Is it possible to get the install location from the installer? I know it is possible to get the install location when the application is started.
      As a note this was posted in the Flex forum previously.
        • 1. Re: AIR Application Install Location
          tzeng Adobe Employee
          If you look into the installation log (.airappinstall.log in user's home directory. You do need to create this file before installation),
          you can find the line:
          Destination for Installed application is: XXXXX
          You should be able to get the location.
          -ted
