This content has been marked as final.
Show 1 reply
1. Re: help in RegExp
Newsgroup_User Jul 17, 2008 5:53 AM (in response to AScracker)AScracker,
> hi
Hi!
> i need to convert the code (0,0,2,84,69,93,76,49) as
> 0,0,2,84,69,93,76,49.
Okay.
> How can use the regular exp for this code
There are a couple ways it can be done, but in this case I would
probably use the
String.replace() method. It could work like this:
var str:String = "(0,0,2,84,69,93,76,49)";
var pattern:RegExp = /\(([^)]+)\)/;
str = str.replace(pattern, "$1");
trace(str);
You can see the str variable as your original string. The pattern
variable is a RegExp instance, set to this pattern: \(([^)]+)\) That looks
for a left parenthesis followed by any character that isn't a right
parenthesis (at least once) followed by a right parenthesis. The
between-the-parentheses match is stored in one of the RegExp's "memory
slots," like a calculator's M button. The first slot is $1, which is what
the replace() method uses to replace the match.
David Stiller
Co-author, Foundation Flash CS3 for Designers
http://tinyurl.com/2k29mj
"Luck is the residue of good design."
