4 Replies Latest reply on Nov 20, 2009 6:50 AM by Bob Stucky
    JS - Conditional include
    madhenkie
      Is it possible to conditionaly include a file
      for example:
      if (something == true){
           #include "first.jsx"
      } else {
           #include "second.jsx"
        • 1. Re: JS - Conditional include
          Dirk Becker Level 4
          You could use eval() the same way as the jsxbin loader of the XHTML Export.
          Dirk
          • 2. Re: JS - Conditional include
            madhenkie Level 1
            Do you mean like this:
            if (condition) {
                 eval("#include \"somefile.jsx\"");
            } else {
                 eval("#include \"anotherfile.jsx\"");
            • 3. Re: JS - Conditional include
              Dirk Becker Level 4
              No. Of course I should have looked twice, the relevant source has been changed since CS3.
              With namespaces removed, the code looked like this:
              getScriptsFolderPath = function() {
              try {
              var script = app.activeScript;
              } catch(e) {
              // we are running from the ESTK
              var script = File(e.fileName);
              return script.path + '/../';
              loadScript = function(filename) {
              var file = File(getScriptsFolderPath() + filename );
              var script = undefined;
              if (file.exists) {
              file.open();
              script = file.read();
              file.close();
              // we return the script rather than calling eval() right here
              // because the results of eval() are only valid within the
              // scope of the function that calls eval()
              return script;
              // load the script
              script = loadScript('XHTMLExportMenuItem.jsxbin');
              if( script != undefined) {
              // execute it
              eval(XHTMLExportMenuItemLoader.script);
              • 4. Re: JS - Conditional include
                Bob Stucky Adobe Employee
                The best way to load a script file is $.evalFile()
                It doesn't have the scoping problem of eval()
                Regards
                Bob
