0 Replies Latest reply on Nov 20, 2009 8:01 AM by Paul Reilly
    [svn:fx-trunk] 12043: * Weekly batch of compiler fixes.
    Paul Reilly
      Revision: 12043
      Revision: 12043
      Author:   preilly@adobe.com
      Date:     2009-11-20 08:00:57 -0800 (Fri, 20 Nov 2009)
      Log Message:
      • Weekly batch of compiler fixes.
      QE notes: mustella server runs can use -debug or
                -omit-trace-statements=false now.
      Doc notes: Yes, new option.
      Bugs: SDK-24229, SDK-24228, SDK-24224, SDK-24271, SDK-24001, SDK-24075
      Reviewer: Pete F (SwcChecksums.java, PreLink.java), Corey (everything else)
      Tests run: full cyclone, which had some mxunit and junit failures,
                 which I fixed and confirmed by rerunning the failed tests.
                 Mustella had a bunch of VideoPlayer related failures, which
                 I assume a related to the switch to the OSMF player.
      Is noteworthy for integration: Yes, added new option -omit-trace-statements,
                                     the default is true for production.
      Code-level description of changes:
        modules/compiler/src/java/flex2/configuration_en.properties
          Added details for report-invalid-styles-as-warnings and
          show-invalid-css-property-warnings to finish off SDK-24001.
        modules/compiler/src/java/flex2/tools/SwcChecksums.java
          Take non-SWC theme files into consideration when generating the
          SWC checksum, because getThemeInfo() in CompilerConfiguration has
          doChecksum() returning false.  This fixes part of SDK-24271.
        modules/compiler/src/java/flex2/tools/PreLink.java
          Modified processMainUnit() to replace duplicates returned from
          StylesContainer.processDependencies() rather than skipping them.
          This fixes the rest of SDK-24271, which was introduced by revision
          11575.
        modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          Added omit-trace-statements option.
        modules/compiler/src/java/flex2/compiler/common/DefaultsConfigurator.java
        frameworks/flex-config.xml
          Added omit-trace-statements default of true.
        modules/compiler/src/java/flex2/compiler/SymbolTable.java
          Modified constructor to turn on trace statement omission when
          debug is false and omitTraceStatements is true.
        modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
          Essentially revert the fix for SDK-23662, which fixes SDK-24229,
          SDK-24228, and SDK-24224.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24229
          http://bugs.adobe.com/jira/browse/SDK-24228
          http://bugs.adobe.com/jira/browse/SDK-24224
          http://bugs.adobe.com/jira/browse/SDK-24271
          http://bugs.adobe.com/jira/browse/SDK-24001
          http://bugs.adobe.com/jira/browse/SDK-24075
          http://bugs.adobe.com/jira/browse/SDK-23662
      Modified Paths:
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/DefaultsConfigurator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_en.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/SwcChecksums.java
