0 Replies Latest reply on Nov 20, 2009 8:14 AM by mraccess1977
    [svn:fx-trunk] 12045: Update accessibility naming logic.
    mraccess1977
      Revision: 12045
      Revision: 12045
      Author:   jon.avila@ssbbartgroup.com
      Date:     2009-11-20 08:14:25 -0800 (Fri, 20 Nov 2009)
      Log Message:
      Update accessibility naming logic.  When accessibility name is explicitly set use that name, otherwise use name provided by getName function in accImpl for component, else use toolTip for component (if present).  Form heading name and item name are still prepended with required field notation if they exist.  Form heading and form item logic now uses accessible name if set on those components including with string containing space is used to silence form heading or form item from being announced.  Required Field string was localized into controls.properties.
      QE notes: none
      Doc notes: none
      Bugs: n/a
      Reviewer: Gordon
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/AccImpl.as
