Good morning all,
I want to show certain cfinput fields if specifc data is returned. For instance, I query a table and if a model number contains a 2 then, show <cfformgroup name="two"> else show <cfformgroup name="One"> elseif model contain 4 then, <cfformgroup name="Four">. I want to use this method to reduce user error by having them select from a drop down.
Thanks in advance,
djkhalif
This has the potential to be a goat's breakfast. How many records does the query return? If it returns more than one, do you want a dropdown for each record or one dropdown for everything?
What if a model number contains a 2 and a 4?
Dan,
The query will only return one record, one model per workorder. That model can only return with a 2, 4 or without a number for 1.
For example:
Work Order: 553901
Item: ab9944-13
Model: 2XTHC-7 or 4XTH-7 or XTHC
The Model has to be one or the other. So, I need to record the amp for cell (2, 4 or 1). Each number represents a cell count. I don't want user to enter in more or less than the necessary cell. I could do 4 inputs and let the user determine by model but user error.
djkhalif
