0 Replies Latest reply on Nov 20, 2009 10:38 AM by CoreyRLucier
    [svn:fx-trunk] 12052: We now issue runtime warnings for incompatible embedded fonts as we detect their use .
    CoreyRLucier Adobe Employee
      Revision: 12052
      Revision: 12052
      Author:   clucier@adobe.com
      Date:     2009-11-20 10:38:19 -0800 (Fri, 20 Nov 2009)
      Log Message:
      We now issue runtime warnings for incompatible embedded fonts as we detect their use.
      QE notes: You might want to create a couple tests around this.
      Doc notes: None.
      Bugs: SDK-23920.
      Reviewer: Alex, Darrell
      Tests run: Checkin
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23920
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/bundles/en_US/core.properties
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridColu mn.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/EmbeddedFontRegistry.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IEmbeddedFontRegistry.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextField.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextFormat.as
          flex/sdk/trunk/frameworks/projects/spark/src/mx/core/UIFTETextField.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Label.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichEditableText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/utils/TextUtil.as
