0 Replies Latest reply on Nov 20, 2009 10:59 AM by Jason Szeto
    [svn:fx-trunk] 12056: PopUpAnchor bug fixes
    Jason Szeto Level 3
      Revision: 12056
      Revision: 12056
      Author:   jszeto@adobe.com
      Date:     2009-11-20 10:59:23 -0800 (Fri, 20 Nov 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-24026 - PopupAnchor throws RTE if removed from stage and has no children
      Added null check
      http://bugs.adobe.com/jira/browse/SDK-23541 - DropDownList does not position dropDown correctly if popUpWidthMatchesAnchorWidth is set to "false"
      The problem is that when the popUpPosition is set to "left" and the popUp doesn't have an explicit width, its measured size is not updated in time for the popUp to be positioned. The solution is to force a measure pass by calling validateNow on the popUp.
      QE notes: None
      Doc notes: None
      Bugs: SDK-24026, SDK-23541
      Reviewer: Alex, Glenn
      Tests run: PopUpAnchor, DropDownList, ComboBox
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/PopUpAnchor.as
