0 Replies Latest reply on Nov 20, 2009 1:24 PM by bbones
    Problem with NetConnection in Flex using Flash Media Server
    bbones
      I'm attempting to place a function on a NetConnection instance, and from everything I've read, I should be able to do that. Unfortunately, I'm getting an error when I compile. Here's my code, and my error is below the code, please let me know if you have a solution. Thanks for the help!
      import mx.rpc.events.ResultEvent
      import flash.net.NetConnection;
      import flash.net.navigateToURL;
      import flash.events.NetStatusEvent;
      import flash.events.StatusEvent;
      import flash.text.TextField;
      public var nc:NetConnection;
      // init is called on creationComplete
      public function init():void{
           nc = new NetConnection;
           nc.addEventListener(NetStatusEvent.NET_STATUS,onConnect);
           nc.connect("rtmp://localhost/FMSTesting");
      public function onConnect(event:NetStatusEvent):void{
              myText.text = nc.connected + event.info.code;
      //nc.myFunction is the function that will be called
      //from the main.asc server side file and this is where I get
      // the red x in Flex Builder 3 telling me there's an error
      nc.myFunction = function():void{
      error generated by the nc.myFunction line is:
      1119:Access of possibly undefined property myFunction through a reference with static type flash.net:NetConnection
      I tried putting the function declaration inside the onConnect handler and inside the init function, niether will remove the error.
