9 Replies Latest reply on Nov 21, 2009 5:26 AM by Ned Murphy
    loadMovieNum
    erin027
      Hello Experts...
      I am using Actionscript 2.0 and I'm a newbie.
      anyway, I have four swf files:
      Main.swf
      Mac1.swf, Mac2.swf, Mac3.swf
      On Main.swf, I have three frames and each frames it has these action scripts
      Mac1.swf:
      stop();
      unloadMovieNum(1);
      loadMovieNum("mac1.swf", 1);
      Mac2.swf:
      stop();
      unloadMovieNum(1);
      loadMovieNum("mac2.swf", 1);
      Mac3.swf:
      stop();
      unloadMovieNum(1);
      loadMovieNum("mac3.swf", 1);
      What I need to do is when mac1.swf loaded on Main.swf and when it reaches end of the movie, I want to load mac2.swf on Main.swf. Is there anyway that I can have actionscript to tell mac1.swf to gotoAndStop(2) on Main.swf? so that it will load the mac2.swf?
      Thanks in advance
        • 1. Re: loadMovieNum
          One way, if you have the ability to edit the files being loaded, is to include a command at the end of the loaded movie:
          _parent.nextFrame();
          • 2. Re: loadMovieNum
            erin027 Level 1
            Thanks, but it didn't work.
            If I add _parent.nextFrame(); on Mac1.swf, it just loops itself.
            On the last frame of Mac1.swf, I need an actionscript to gotoAndStop(2) on Main.swf so that it will load the mac2.swf on Main.swf.
            Did I explain it well?
            • 3. Re: loadMovieNum
              ned gave code for the last frame of the loaded swf.   despite your feeling you should use something with gotoAndStop(2), using _parent.nextFrame() is better.
              the only thing it won't do, is return your main timeline to frame 1 when the last swf finishes.  for that you should use, _parent.gotoAndStop(1) on the last frame of the last swf (if you want to re-load the first swf).
              p.s.  you don't need to use unloadMovieNum(1) on any of your main timeline frames.
              • 4. Re: loadMovieNum
                erin027 Level 1
                It's funny.. end of the mac1.swf, it keeps playing mac1.swf over and over again.
                when you said "_parent..", is it Main.swf or mac1.swf? it should be main.swf, correct?
                • 5. Re: loadMovieNum
                  using _parent within the loaded movie's (mac1.swf) main timeline should target the main.swf file's timeline.  You might also try using _root, or even _level0.
                  • 6. Re: loadMovieNum
                    oops, you're loading into _level1.  you must use:
                    _level0.nextFrame();  // in all loaded swfs except the last
                    and
                    _level0.gotoAndStop(1);  // in the last loaded swf.
                    • 7. Re: loadMovieNum
                      erin027 Level 1
                      Thank you!
                      level0... worked, but _parent or _root didn't work.
                      Thank you again!
                      • 8. Re: loadMovieNum
                        that's correct.  only _level0 will work because you're loading into a non-zero level.
                        that's so unusual for experienced flash users that ned and i both forgot that (momentarily).  i almost never use non-zero levels and i suspect ned doesn't often use them, either.
                        • 9. Re: loadMovieNum
                          I think I last used loadMovieNum about 6 years ago, and except for needing it to solve someone else's posting recently, having to use anything of the _level# syntax has been non-existent for me.
