0 Replies Latest reply on Nov 20, 2009 4:41 PM by GordonSmith
    [svn:fx-trunk] 12072: Extracted the DITA XML files from textLayout.swc ( which shouldn't actually have them) and checked them into frameworks/ projects/textLayout/bundles/en_US/docs.
    GordonSmith Level 4
      Revision: 12072
      Revision: 12072
      Author:   gosmith@adobe.com
      Date:     2009-11-20 16:41:12 -0800 (Fri, 20 Nov 2009)
      Log Message:
      Extracted the DITA XML files from textLayout.swc (which shouldn't actually have them) and checked them into frameworks/projects/textLayout/bundles/en_US/docs. We will treat textLayout.swc the same way that we treat playerglobal.swc, meaning that we will build "fat resource bundle SWCs" for the various tooling locales, so that Flash Builder can have localized code hints for TLF.
      TLF will be changing its build process so that we get a non-FAT textLayout.swc from them, and the DITA XML files will instead be in a bundles/en_US/docs folder next to the src folder in their opensource zip. We'll check them in along with the source.
      There is no build script yet for building /textLayout_rb.swc, but there are empty.properties files, like in projects/playerglobal to help do this.
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: None
      Tests run: None
      Is noteworthy for integration: Yes. This is a first step to getting localized codehints for TLF.
      Added Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/de_DE/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/de_DE/empty.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flash.text.ime.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.compos e.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.contai ner.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.conver sion.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.edit.x ml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.elemen ts.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.events .xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.factor y.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.format s.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.operat ions.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.utils. xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.undo.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/packages.dita
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/empty.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/fr_FR/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/fr_FR/empty.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/ja_JP/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/ja_JP/empty.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/ru_RU/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/ru_RU/empty.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/zh_CN/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/zh_CN/empty.properties
