0 Replies Latest reply on Nov 20, 2009 4:56 PM by GordonSmith
    [svn:fx-trunk] 12073: Fixed FTETextField so that with htmlText, what-you-get-is-not-what-you-set, at least if there is no styleSheet.
    GordonSmith Level 4
      Revision: 12073
      Revision: 12073
      Author:   gosmith@adobe.com
      Date:     2009-11-20 16:56:36 -0800 (Fri, 20 Nov 2009)
      Log Message:
      Fixed FTETextField so that with htmlText, what-you-get-is-not-what-you-set, at least if there is no styleSheet. You can now set terse HTML like "Hello
      World
      " and get back verbose HTML containing the computed formats. This is the way that TextField works, although FTETextField's verbose HTML is a little more verbose in the sense of starting with
      Last bug for signoff of MXFTEText.css feature?
      QE notes: None
      Doc notes: None
      Bugs: SDK-24221
      Reviewer: Carol
      Tests run: None
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24221
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/mx/core/FTETextField.as
